Remove All Field Mapping for arcpy.FeatureClassToFeatureClass_conversion
4806
5
04-06-2015 01:05 PM
RichardKammer
Can anyone please tell me why this is not working? When I use the FeatureClassToFeatureClass_conversion geoprocessing tool, I do not want any of the existing fields to be in the output file.
fldmap = arcpy.FieldMappings()
remfldmap = fldmap.removeAll()
arcpy.FeatureClassToFeatureClass_conversion(lyr,GDB,fc,"",remfldmap,"")
DarrenWiens2
MVP Honored Contributor
I'm not sure what the best way to do what you want to do is, but here is my understanding of what's going wrong:
>>> print type(fldmap)
<class 'arcpy.arcobjects.arcobjects.FieldMappings'>
>>> print type(remfldmap)
<type 'NoneType'>
You're trying to use 'remfldmap' as an empty field map object, when it is actually a completely empty object (i.e. not a field map).
edit: you can generate unattributed geometries using code like below:
>>> polygons = []
... with arcpy.da.SearchCursor("YOUR_FEATURE_CLASS","SHAPE@") as cursor:
...     for row in cursor:
...         polygons.append(row[0])
... arcpy.CopyFeatures_management(polygons,r"OUTPUT_FEATURE_CLASS")
DarrenWiens2
>>> print type(fldmap)
<type 'NoneType'>
>>> polygons = []
DanPatterson_Retired
don't have anything to try it on, but my guess it is one of those methods that you can't assign but is done in place ... did you just try
import arcpy
input_shp = 'c:/temp/Phish_Nyet3.shp'
fm = arcpy.FieldMap()
flds = arcpy.ListFields(input_shp)
for field in flds:
if not field.required:
  fm.addInputField(input_shp,field.name)
  print field.name
fm.removeAll()
fldMapping = arcpy.FieldMappings()
fldMapping.addFieldMap(fm)
arcpy.FeatureClassToFeatureClass_conversion(input_shp,'c:\\temp\\',
                                            'All_gone.shp',
                                            field_mapping=fldMapping)
sorry don't have arc running now to test it
EDIT the original was done in the interactive window.  I removed and pasted if from a script window just in casei the indenentation was throwning people
curtvprice
MVP Esteemed Contributor
My suggestion: create an empty feature class with the Create Feature Class tool, and dump your data onto it with Append_management with the "NO_TEST" option.
RichardKammer
Dan,
I get the following error when I run you example.
It errors on the fm.addInputField(input_shp,field.name) line.
RuntimeError: FieldMap: Error in adding input field to field map
I edited the original post....have a look
