Run geoprocessing task on hosted featureservices through python
512
06-29-2017 07:07 AM
by Anonymous User
Not applicable
I'm trying to create a script that will access an AGOL hosted feature service (polygon), run a FeatureToPoint geoprocessing task against it, and overwrite a separate hosted feature service. Below is a code snippet
    outFC = "C:/GIS/AmericanWater/JamesMitchell/Poly2Point.gdb/WVAW_LineB_Projects_Points"
    shh = securityhandlerhelper.securityhandlerhelper(securityinfo=securityinfo)
    if shh.valid == False:
        print shh.message
    else:
        fl= FeatureLayer(
            url=PolyUrl,
            securityHandler=shh.securityhandler,
            proxy_port=proxy_port,
            proxy_url=proxy_url,
            initialize=True)
        sql = "MapReady = 'Yes'"
        resFeats = fl.query(where=sql)
        arcpy.FeatureToPoint_management(resFeats,outFC,"CENTROID")
        fl = PointUrl
        print fl.updateFeature(features=resFeats)
    print "Finished"
I get the following message when it reaches the FeaureToPoint geoprocessing tool
  File "G:\ArcMap Settings\Python\Poly2Point.py", line 53, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\management.py", line 2583, in FeatureToPoint
    raise e
RuntimeError: Object: Error in executing tool
It seems like the tool doesn't like that my input features are coming from a AGOL hosted service. Does this matter? Is there a way around this?
James
