Greetings and thanks for the help so far.I had high hopes regarding the spatial reference issue, but I'm still not getting this to work. I've got the code updated to match Wayne's example.import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
DOQQImport = arcpy.mapping.ListLayers(mxd, 'DOQQImport', df)[0]
sr_dataframe = df.spatialReference
sr_featureclass = arcpy.Describe(DOQQImport).spatialReference
arcpy.env.outputCoordinateSystem = sr_dataframe
myPt = arcpy.Point((df.extent.XMax + df.extent.XMin)/2.0, (df.extent.YMax + df.extent.YMin)/2.0)
myPtGeometry = arcpy.PointGeometry(myPt)
##fc = 'points'
##cursor = arcpy.da.InsertCursor(fc, ["SHAPE@XY"])
##xy =(myPt.X, myPt.Y)
##cursor.insertRow([xy])
arcpy.AddMessage("\nThe fetched polygon layer from the TOC, {0}".format(DOQQImport.name))
arcpy.AddMessage("\nThe data frame spatial reference name: {0}".format(sr_dataframe.name))
arcpy.AddMessage("\nThe feature class (to select by) spatial reference name: {0}".format(sr_featureclass.name))
arcpy.AddMessage("\nThe data frame centerpoint (myPt) - X: {0} Y: {1}".format(myPt.X, myPt.Y))
arcpy.AddMessage("\nThe geometry (myPtGeometry) - {0} {1}".format(myPtGeometry.firstPoint.X, myPtGeometry.firstPoint.Y))
arcpy.AddMessage("\n...now proceeding with the selection, please wait...\n")
arcpy.SelectLayerByLocation_management(DOQQImport, 'INTERSECT', myPtGeometry)
arcpy.RefreshActiveView()
del df, mxd
It successfully runs; here's my output:[INDENT]Executing: gotoSiteLatLong
Start Time: Tue Jun 11 14:38:19 2013
Running script gotoSiteLatLong...
The fetched polygon layer from the TOC, DOQQImport
The data frame spatial reference name: NAD_1983_UTM_Zone_15N
The feature class (to select by) spatial reference name: GCS_WGS_1984
The data frame centerpoint (myPt) - X: 466834.903914 Y: 4975689.29185
The geometry (myPtGeometry) - 466834.903914 4975689.29185
Completed script gotoSiteLatLong...
Succeeded at Tue Jun 11 14:38:24 2013 (Elapsed Time: 5.00 seconds)[/INDENT]
However, I still don't get any selected polygons. I tried changing the data frame coordinate system to match the feature class with similar results. Using the commented out code,##fc = 'points'
I was able to add a point at the center of my current extent, so my geometry is indeed creating a point in the correct location. And there are polygons in my feature class (DOQQImport) that cover the point.I'm stumped as to what I'm missing.Scott
