Hello,I am trying to select features by location from the "tableName_vctor" layer as defined (and highlighted in red), then export them to a new shapefile and am receiving the following errors (refer to the blue section):ERROR 000622: Failed to execute (Select Layer By Location). Parameters are not valid.ERROR 000628: Cannot set input into parameter search_distance.any insight as to how to fix these errors is much appreciatedthank-you in advance! try:
# Iterates through each of the input text files
for v in list(table):
# Removes the file extension
tableName = os.path.splitext(v)[0]
# Variables
tableName_line = tableName + str("_line.shp")
tableName_vctor = tableName + str("_vctor.shp")
tableName_e = tableName + str ("_e.shp")
gate = r"C:\gis\gate.shp"
tableName_sim = tableName + str("_sim.shp")
# Creating vectors from xy coordinates
gp.Toolbox = r"C:\Program Files\ArcGIS\ArcToolbox\Toolboxes\Military Analyst Tools.tbx"
gp.TableToLine_ma(v, tableName_line, "Decimal Degrees", "sLat", "sLon", "eLat", "eLon", "False", "False")
gp.Project_management(tableName_line, tableName_vctor, "PROJCS['LCC']")
#Selecting vectors that intersect a line, then points that intersect the vector, then removing the initial selection
gp.SelectLayerByLocation(tableName_vctor, "intersect", gate, "NEW_SELECTION")
gp.SelectLayerByLocation(tableName_e, "intersect", tableName_vctor, "ADD_TO_SELECTION")
gp.SelectLayerByLocation(tableName_vctor, "intersect", gate, "REMOVE_FROM_SELECTION")
# Write the selected features to a new feature class in the folder
gp.CopyFeatures(tableName_sim, r"C:\gis\temp")
except:
#If an error occurred while running the script, then print the messages
print gp.GetMessages()
