I've read through most of the other similar questions and nothing so far has addressed my issue; most are about syntax.
I'm trying to select by attribute from a Feature Layer. But every time, Arc announces that it succeeded and nothing is selected. It works just fine using the same expression to select from a Table View. Any ideas?
expression = arcpy.AddFieldDelimiters(tempFeatureLayer, "BLDG_ID") + " LIKE '{0}%'".format(county)
arcpy.SelectLayerByAttribute_management(tempFeatureLayer, "NEW_SELECTION", expression)
if int(arcpy.GetCount_management(tempFeatureLayer)[0]) > 0:
arcpy.DeleteRows_management(tempFeatureLayer)
It's an SDE Database feature class, if that makes a difference.
I've also tried rewriting the expression as below with the same result:
expression = """ "BLDG_ID" LIKE '37019%'"""
and
expression = "BLDG_ID LIKE '37019%'"
