Should I use the "AddMessage" instead of GetMessage ?
3840
02-12-2015 07:14 AM
PROBERT68
Hi All,
I am trying to  write a script to call a variable to inform that your exported has been completed. Please take a take a look at here to see if this is correct or not .
Thanks
# Name:        Export PDF
# Purpose:     To export MapLayout to PDF
# Author:      Robert.Pollock
# Created:     10/02/2015
# Copyright:   (c) Robert.Pollock 2015
import arcpy.mapping, os
str = "Your PDF exported has been delivered to your folder, Thank you"
mxd = arcpy.mapping.MapDocument("E:\FY2015_projects\Mimbres Ranch River\Mimbres River Ranch2.mxd")
arcpy.mapping.ExportToPDF(mxd,r"E:\workspace\PDF\MimbresRiverRanch34x44")
## Print message to complete the exported processed
print arcpy.GetMessages(print str.rjust(50, '0')
Thank you for your help
JakeSkinner
Esri Esteemed Contributor
Hi Robert,
If you want to just add a message that the PDF has been exported, I would recommend using arcpy.AddMessage.  The GetMessage should be used when you want to return a geoprocessing tool message.
JakeSkinner
Hi Robert,
