Sort layers in TOC using arcpy
4504
12-31-2015 05:00 AM
Yaron_YosefCohen
Occasional Contributor II
i try to sort layers in the TOC, in ascending or by name alphbetical with this code:
import arcpy
mxd = arcpy.mapping.MapDocument(r"D:\desktop\Project\project.mxd")
df = arcpy.mapping.ListDataFrames(mxd)[0] # Assuming one data frame
group_lyr = [lyr for lyr in arcpy.mapping.ListLayers(mxd) if lyr.isGroupLayer][0] # The temp group layer should be the only one
lyr_names = sorted(lyr.name for lyr in arcpy.mapping.ListLayers(mxd) if lyr.isFeatureLayer)
for name in lyr_names:
    arcpy.mapping.MoveLayer(df, group_lyr, arcpy.mapping.ListLayers(mxd, name)[0], "BEFORE")
    print name +' sorted'
arcpy.mapping.RemoveLayer(df, group_lyr)
and got:
land use sorted
river sorted
but the TOC do't sorted. For clarity, i saw this question in arcgis 10.0 - Arc GIS 10.1 - How to sort Layers ascending at TOC in "List by drawing order" - Geogra...
I work with arc view 10.3. I know it possible with extension, but i have no extensions.
Is it possible to do it with python?
Tags (3)
WesMiller
Regular Contributor III
I don't see where you saved the document. You may want to use savACopy() till you get what you want.
MapDocument—Help | ArcGIS for Desktop
WesMiller
DanPatterson_Retired
also, it makes little sense to sort things alphabetically... for example
...  landuse, river   in this scenario, you could have agricultural land over top of the river
...  fire station, ownership .... where did the fire station go?
... bridge, river .... the Chunnel?
Order things by geometry first, then conceptually within each grouping to ensure that you don't obliterate features that should be seen
Yaron_YosefCohen
in this project i don't need to sort geometry first. I do need to sort alphabetically and also by numbers.
