Street Centerline "From and To Streets"
3918
29
06-20-2017 11:52 AM
KevinCross2
New Contributor III
I am trying to update our street center line information that does not have the "From Street" or "To Street" field populated.  All our data has is "On Street".   Is there an "easy" way to write a script or is there a set of tools that can be used to help populate this information automatically?
KevinCross2
New Contributor III
Sorry for the late reply.  I've been on vacation and we've been in the process of changing vendors for our GIS hosting.  I ran the script on my full data set and it looks like it did a great job breaking things where I needed them to.  There looks to be some clean up on things, but that's to be expected.  I appreciate your help on this.  This has saved me a lot of man hours doing it manually!
XanderBakker
Esri Esteemed Contributor
Hi Kevin Cross , glad it you found the script useful. It might be necessary to do some editing on the data before and afterwards, since it does not account for all situations. Did you catch any other inconveniences? In case the script solved your question, please mark that post as the correct answer.
KevinCross2
New Contributor III
The only "inconvenience" I found was when it found more than one "From or To" Street it put multiple street names in the field.  I'd like to see it be able to work " West to East" or "North to South" orientation depending on which way the "On" street is going and use only 1 street as the "From or To" Street.
Below is a sample of what I'm getting.
XanderBakker
OK, so if I understand this correctly... Let's look at the following record:
Blair Ln goes from Cook Dr to the streets Blairmont Dr and E. Blairmont Dr.:
Would this be "West to East" and therefore "Blairmont Dr" as To Street?
I do see that there are multiple streets that mention the same street twice. This could be corrected.
KevinCross2
New Contributor III
That is correct.
XanderBakker
The easiest first correction (eliminate multiple streets with the same name) would be to change lines 49 and 53:
# line 49:
                from_streets = ', '.join(list(set([dct[o][1] for o in from_oids])))
# line 53:
                to_streets = ', '.join(list(set([dct[o][1] for o in to_oids])))
I will look at the " West to East" or "North to South" orientation to see what I come up with...
XanderBakker
Hi kevin.cross ,
Here is another go on the N+W preference (please run on a copy of your data):
# Name:        from_to_street.py
# Purpose:
# Author:      xbakker
# Created:     21/06/2017
import arcpy
def main():
    fc = r'C:\GeoNet\FromToStreet\gdb\GeoNet Street Sample.gdb\LebStreetSample_MP2SP'
    fld_fullname = 'Fullname'
    fld_from = 'From_Street'
    fld_to = 'To_Street'
    tolerance = 5  # 5 feet distance tolerance for finding intersections
    min_angle = 45  # to detect angle intersections
    sr = arcpy.Describe(fc).spatialReference
    flds = ('OID@', 'SHAPE@', fld_fullname)
    dct = {r[0]: [r[1], r[2]] for r in arcpy.da.SearchCursor(fc, flds)}
    print "dict filled..."
    cnt = 0
    dct_res = {}  # fill with results
    for oid, lst in dct.items():
        polyline = lst[0]
        full_name = lst[1]
        if full_name != ' ':
            cnt += 1
            if cnt % 50 == 0:
                print "Processing:", cnt
            from_pnt = polyline.firstPoint
            to_pnt = polyline.lastPoint
            # get a list of candidates for from and to points
            from_oids = SelectFromToCandidates(oid, full_name, from_pnt, dct, tolerance, sr)
            to_oids = SelectFromToCandidates(oid, full_name, to_pnt, dct, tolerance, sr)
            # print "  - before filter: ",  full_name, oid, from_oids, to_oids
            if len(from_oids) > 0:
                from_oids = FilterListOnAngles(dct, oid, from_oids, min_angle)
            if len(to_oids) > 0:
                to_oids = FilterListOnAngles(dct, oid, to_oids, min_angle)
            # implement the  " West to East" or "North to South" orientation pref
            if len(from_oids) > 1:
                seg_from = polyline.segmentAlongLine(0.0, 0.05, True)
                from_oids = AnalyzeOrientationNWvsSE(dct, from_oids, seg_from, from_pnt)
            if len(to_oids) > 1:
                seg_to = polyline.segmentAlongLine(0.95, 1.0, True)
                to_oids = AnalyzeOrientationNWvsSE(dct, to_oids, seg_to, to_pnt)
            # print "  - after filter: ", full_name, oid, from_oids, to_oids
            if len(from_oids) == 0:
                from_streets = ''
            else:
            if len(to_oids) == 0:
                to_streets = ''
            else:
            if from_streets in [' ' , ' ,  ']:
                from_streets = ''
            if to_streets in [' ' , ' ,  ']:
                to_streets = ''
            # print oid, " - From:", from_streets, from_oids
            # print oid, " - To  :", to_streets, to_oids
            dct_res[oid] = [oid, from_streets, to_streets]
    print "update cursor..."
    cnt = 0
    updates = 0
    flds = ('OID@', fld_from, fld_to)
    with arcpy.da.UpdateCursor(fc, flds) as curs:
        for row in curs:
            cnt += 1
            oid = row[0]
            if oid in dct_res:
                result = dct_res[oid]
                curs.updateRow(tuple(result))
                updates += 1
            if cnt % 50 == 0:
                print"processing row:", cnt, " - updates:", updates
def AnalyzeOrientationNWvsSE(dct, candidates, seg, pnt):
    best_angle = None
    best_candidate = None
    sr = seg.spatialReference
    direction_main = GetDirectionOfSegment(seg)
    angle_main = GetAngleSegment(seg)
    pntg = arcpy.PointGeometry(pnt, sr)
    for candidate in candidates:
        polyline = dct[candidate][0]
        # get start segment and end segment of polyline
        start1 = polyline.segmentAlongLine(0, 10, False)
        end1 = polyline.segmentAlongLine(polyline.length-10, polyline.length, False)
        # determine distance start segment and end segment to intersecting line
        d_start = start1.distanceTo(pntg)
        d_end = end1.distanceTo(pntg)
        if d_start < d_end:
            # start is closer to intersecting line
            seg1 = start1
        else:
            # end is closer to intersecting line
            seg1 = end1
        angle_cand = GetAngleSegment(seg1)
        direction_cand = GetDirectionOfSegment(seg1)
        score = GetScoreAngle(direction_main, direction_cand)
        if best_angle == None:
            best_angle = [angle_cand, direction_cand, score]
            best_candidate = candidate
        else:
            if score < best_angle[2]:
    return [best_candidate]
def GetScoreAngle(direction_main, direction_cand):
    dct = {'N': ['W', 'SW', 'NW', 'E', 'NE', 'SE', 'S', 'N'],
           'S': ['W', 'NW', 'SW', 'E', 'SE', 'NE', 'N', 'S'],
           'W': ['N', 'NE', 'NW', 'S', 'SE', 'SW', 'E', 'W'],
           'E': ['N', 'NW', 'NE', 'S', 'SW', 'SE', 'W', 'E'],
           'NW': ['N', 'W', 'NE', 'SW', 'S', 'E', 'SE', 'NW'],
           'SW': ['NW', 'N', 'W', 'SE', 'S', 'E', 'NE', 'SW'],
           'NE': ['NW', 'W', 'N', 'SE', 'S', 'E', 'SW', 'NE'],
           'SE': ['N', 'W', 'NW', 'SW', 'NE', 'S', 'E', 'SE']}
    lst = dct[direction_main]
    return lst.index(direction_cand)
def GetDirectionOfSegment(seg):
    angle = GetAngleSegment(seg)
    return GetAngleDirection(angle)
def GetAngleDirection(angle):
    angle_defs = [('N', -22.5, 22.5), ('NE', 22.5, 67.5), ('E', 67.5, 112.5),
                  ('SE', 112.5, 157.5), ('S', 157.5, 180.1), ('S', -180, -157.5),
                  ('SW', -157.5, -112.5), ('W', -112.5, -67.5), ('NW', -67.5, -22.5)]
    direction = 'Not Set'
    for angle_def in angle_defs:
        if angle >= angle_def[1] and angle < angle_def[2]:
            direction = angle_def[0]
            break
    return direction
def FilterListOnAngles(dct, oid, candidates, angle_tolerance):
    polyline = dct[oid][0]
    oids_ok = []
        polyline_cand = dct[candidate][0]
        if ValidateAngle(polyline, polyline_cand, angle_tolerance, oid):
            oids_ok.append(candidate)
    return oids_ok
def ValidateAngle(polyline1, polyline2, angle_tolerance, oid):
    try:
        start1 = polyline1.segmentAlongLine(0, 1, False)
        end1 = polyline1.segmentAlongLine(polyline1.length-1, polyline1.length, False)
        # sr = polyline1.spatialReference
        d_start = start1.distanceTo(polyline2)
        d_end = end1.distanceTo(polyline2)
        if d_start < d_end:
            pntg = polyline2.queryPointAndDistance(polyline1.firstPoint, False)[0]
            seg1 = start1
        else:
            pntg = polyline2.queryPointAndDistance(polyline1.lastPoint, False)[0]
            seg1 = end1
        # get position of projected point on intersecting line
        distance_along = polyline2.measureOnLine (pntg, False)
        # and extract segment
        seg2 = polyline2.segmentAlongLine(max([distance_along -1, 0]),
                            min([distance_along +1, polyline2.length]), False)
        # compare
        compare_angles = [seg1, seg2]
        angle_segs = GetAngleSegments(compare_angles)
        # print "angle_segs 1", angle_segs
        while angle_segs < 0:
            angle_segs += 180
        while angle_segs > 360:
            angle_segs -= 360
        # print "angle_segs 2", angle_segs
        if IsBetween(angle_segs, angle_tolerance, 180 - angle_tolerance) or IsBetween(angle_segs, angle_tolerance + 180, 360 - angle_tolerance):
            return True
        else:
            # print " - NOT IsBetween...", angle_segs
            return False
    except Exception as e:
        print "ValidateAngle ERROR @ OID:", oid
        return False
def IsBetween(val, val_min, val_max):
    if val >= val_min and val <= val_max:
        return True
    else:
        return False
def GetAngleSegment(seg):
    pntg1 = arcpy.PointGeometry(seg.firstPoint, seg.spatialReference)
    pntg2 = arcpy.PointGeometry(seg.lastPoint, seg.spatialReference)
    angle = GetAngle(pntg1, pntg2)
    return angle
def GetAngleSegments(segments):
    try:
        angles = []
        for seg in segments:
            angles.append(angle)
        #print "angles", angles
        angle_between = angles[0] - angles[1]
        return angle_between
    except:
        return None
def GetAngle(pntg1, pntg2):
    '''determine angle of line based on start and end points geometries'''
    return pntg1.angleAndDistanceTo(pntg2, method='PLANAR')[0]
def SelectFromToCandidates(cur_oid, cur_full_name, pnt, dct, tolerance, sr):
    oids = []
        full_name = lst[1]
        if oid != cur_oid:
            # don't include the current polyline in results
            if full_name != cur_full_name:
                # don't include street with the same name
                polyline = lst[0]
                if polyline.distanceTo(pntg) <= tolerance:
                    oids.append(oid)
    return list(set(oids))
if __name__ == '__main__':
    main()
KevinCross2
New Contributor III
Xander,
I just ran this on my original database and it worked FLAWLESS!!  Thank you very much for your help on this.  I appreciate it!
XanderBakker
That is good news! Thanks for sharing and I'm glad it worked!
ahagopian_coj
I know this post is a bit old but I am trying to use your python script to do the same thing - calculate to and from streets per street block/segment.  I keep getting an error and can't figure it out.  PYTHON ERROR.PNG
