I am attempting to create a .dbf or geodatabase table from a csv. At first i attempted to just use the 'Table to Table' tool. I set up the field mappings and everything just right but when i run the tool it completes in mere seconds and says it has done so successfully. However, when i attempt to find the output table there is nothing there. I tried to use the 'Excel to Table' tool, same result. I even went so far as to create the table using arcpy and looping through the csv row by row and inserting those rows into the table with an insertcursor. I even had it print each row right before inserting.
the last portion of the code:
readcsv = csv.reader(opencsv)
for row in readcsv:
if "API" not in row[0]:
print row
icursor.insertRow(row)
a sample of the output:
['5067088870000', '0.000', '30.670', 'IGNACIO-BLANCO', 'PICTURED CLIFFS']
['5067065920000', '0.251', '370.725', 'IGNACIO-BLANCO', 'PICTURED CLIFFS']
['5067062590000', '0.390', '1021.573', 'IGNACIO-BLANCO', 'PICTURED CLIFFS']
['5067062570000', '0.446', '1100.212', 'IGNACIO-BLANCO', 'PICTURED CLIFFS']
['5067050960000', '0.131', '952.399', 'IGNACIO-BLANCO', 'MESAVERDE']
['5067088870000', '0.000', '1524.118', 'IGNACIO-BLANCO', 'MESAVERDE']
['5067052140000', '7.215', '5309.192', 'IGNACIO-BLANCO', 'PICTURED CLIFFS']
['5067051470000', '0.000', '1051.158', 'IGNACIO-BLANCO', 'MESAVERDE']
['5067052460000', '0.121', '2409.044', 'IGNACIO-BLANCO', 'MESAVERDE']
['5067055830000', '0.000', '3503.423', 'IGNACIO-BLANCO', 'MESAVERDE']
['5067052190000', '0.000', '972.064', 'IGNACIO-BLANCO', 'MESAVERDE']
['5067063900000', '0.476', '1023.767', 'IGNACIO-BLANCO', 'PICTURED CLIFFS']
['5067062600000', '0.121', '4221.302', 'IGNACIO-BLANCO', 'MESAVERDE']
Still nothing, the table exists but it is empty. I'm not sure what else i can do to try and get this data into a .dbf or preferably a geodatabase table.
Any help would be greatly appreciated.
