If I edit a field with type GPLong, and then edit a field with a filtered drop-down menu, the numerical field clears/reverts to the previous value. If I edit the first field, press tab or click the background, and then edit the drop-down field, the edits stay.
I observed this with a custom tool and a default Pro tool. It does not appear to happen if you go directly from a numerical to a text field, or a text field to a filtered field.
Is this something that can be "fixed", or is it an unavoidable part of how parameter inputs get validated?
I'm afraid I might not be explaining clearly enough so I will write it like a table too:
- type in numerical field - click directly on a filtered field - change filtered field ✗ numerical field does not keep update | - type in numerical field - press tab or click outside any field - change filtered field ✓ numerical field does keep update | - type in numerical field - click directly on a text field - change (non-filtered) text field ✓ numerical field does keep update | - type in text field - click directly on a filtered field - change filtered field ✓ text field does keep update |
Thanks - Sam
