def updateParameters(self): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" if self.params[0].value and self.params[1].value: ds = self.params[0].value if arcpy.Describe(ds).dataType[:5] != "Table": out = str(self.params[1].value) if os.path.splitext(out)[1] == ".dbf": self.params[1].value = os.path.splitext(out)[0] + ".shp" # the above change does not "stick" - the internal validation # switches it back to .dbf return def updateMessages(self): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" # I needed add this because the default validation # was not finding existing data and warning me. if self.params[1].value: if arcpy.Exists(self.params[1].value): self.params[1].setIDMessage("Error",1251) return
No clue, but perhaps it interprets != "Table" as being true if a shapefile is the input, is there anyway you can check to see whether a *.shp or shapefile or featureclass is checked rather than a table?
>>> arcpy.Describe("polygon_Diss").dataType u'FeatureLayer' >>> arcpy.Describe(r"D:\Users\cprice\work\polygon_Diss.shp").dataType u'ShapeFile'
