Trouble accessing ArcPy in script outside of ArcGIS Pro
2280
6
11-25-2020 06:35 PM
SolanaFoo2
I'm having no luck calling arcpy from a script that uses ArcGIS API for Python as well.
I've added every single path I can think of to the PYTHONPATH and path environment variables.  No luck.  Runs fine with ArcPy and imports arcgis fine as well when run in a Script tool in Pro, or in a Notebook from Pro.
Doesn't run in a Notebook outside of Pro, or called in a bat file where the exe used is here: D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe
Here's the err (I've also seen no _base.py err):
E:\START\CalFire2020_New\PythonScripts\AGOL_Management>"D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe" E:\START\CalFire2020_New\PythonScripts\AGOL_Management\GroupExport.py
  File "E:\AGOL_Management\GroupExport.py",
line 12, in <module>
    import arcpy
  File "D:\Program Files (x86)\ArcGIS\Desktop10.6\arcpy\arcpy\__init__.py", line
 22, in <module>
    from arcpy.geoprocessing import gp
ImportError: cannot import name 'gp'
ManishPatel
Hi @SolanaFoo2 ,
It could possibly be the python environment variable is referencing to a different version.
You can try the following in a bat file
"c:\Program Files\ArcGIS\Pro\bin\Python\scripts\propy.bat" "D:\scriptfile.py"
Cheers,
Manish
SolanaFoo2
Hi Manish,
What does propy.bat do?
Thanks!
ManishPatel
Hi @SolanaFoo2 ,
propy.bat acts as a replacement for calling python.exe
This link will provide you some background info:
https://pro.arcgis.com/en/pro-app/arcpy/get-started/using-conda-with-arcgis-pro.htm
Cheers,
Manish
DanPatterson
MVP Esteemed Contributor
What do you get when you run these from sys?  This is my default path structure minus personal ones.
# ---- NOTE : replace C:\\arc_pro with your installation path
sys.executable
'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\python.exe'
sys.path
['C:\\arc_pro\\Resources\\ArcPy',
 ...snip...,
 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\DLLs',
 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\lib',
 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3',
 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages',
 'C:\\arc_pro\\bin',
 'C:\\arc_pro\\Resources\\ArcToolbox\\Scripts',
 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\future-0.18.2-py3.7.egg',
'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\pytz-2020.1-py3.7.egg',
 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\pywin32_ctypes-0.2.0-py3.7.egg',
 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\pywin32security',
 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\sympy-1.5.1-py3.7.egg',
 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\IPython\\extensions',
... sort of retired...
SolanaFoo2
Hi Dan!
From the cmd prompt:
>>> sys.executable
'D:\\Python27\\ArcGISx6410.6\\python.exe'
>>> sys.path
['', 'C:\\Program Files\\ArcGIS\\Pro\\bin\\Python', 'D:\\Python27\\ArcGISx6410.6
', 'D:\\Python27\\ArcGISx6410.6\\Scripts', 'D:\\Program Files (x86)\\ArcGIS\\Des
ktop10.6\\arcpy', 'D:\\Program Files (x86)\\ArcGIS\\Desktop10.6\\bin', 'D:\\Prog
ram Files\\ArcGIS\\Pro\\bin', 'D:\\Program Files\\ArcGIS\\Pro\\Resources\\ArcPy\
\arcpy', 'D:\\Program Files\\ArcGIS\\Pro\\Resources\\ArcPy', 'D:\\Program Files\
\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3', 'C:\\Program Files\\ArcGIS\\Pro
\\bin\\Python\\envs\\arcgispro-py3\\Lib', 'C:\\Windows\\SYSTEM32\\python27.zip',
'D:\\Python27\\ArcGISx6410.6\\DLLs', 'D:\\Python27\\ArcGISx6410.6\\lib', 'D:\\P
ython27\\ArcGISx6410.6\\lib\\plat-win', 'D:\\Python27\\ArcGISx6410.6\\lib\\lib-t
k', 'C:\\Users\\####\\AppData\\Roaming\\Python\\Python27\\site-packages', 'D:\\P
ython27\\ArcGISx6410.6\\lib\\site-packages', 'D:\\Program Files\\ArcGIS\\Server\
\bin', 'D:\\Program Files\\ArcGIS\\Server\\ArcPy', 'D:\\Program Files\\ArcGIS\\S
erver\\ArcToolBox\\Scripts']
However, trying to run as a batch file like this:
Thanks for the response!
DanPatterson
You mention ArcGIS Pro, but the executable is for python 2.7 which is for arcmap. Which means that you don't have the correct environment activated.
For jupyterlab I use a desktop shortcut to set everything up
# Target
C:\arc_pro\bin\Python\envs\arcgispro-py3\pythonw.exe "C:\arc_pro\bin\python\envs\arcgispro-py3\Scripts\jupyter-lab-script.py"
# Start in
C:\Arc_projects\JupyterNoteBooks
# ---- NOTE \arc_pro\ is the ArcGIS Pro installation folder
# ----- For jupyter notebook
# Target
C:\arc_pro\bin\Python\envs\arcgispro-py3\pythonw.exe "C:\arc_pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-notebook-script.py"
