Price1 = arcpy.GetParameterAsText(0) Price2 = arcpy.GetParameterAsText(1) fcName = "My_lyr" fields = ['Area','Description','Cost'] #Note that 'Area' is type DOUBLE, 'Description' is TEXT, and 'Cost' is DOUBLE CostCursor = arcpy.da.UpdateCursor(fcName,fields) for row in CostCursor: if row[1] == "Category 1": row[2] = (row[0] * Price1) elif row[1] == "Category 2": row[2] = (row[0] * Price2) else: row [2] = 0 CostCursor.updateRow(row) del row del CostCursor
Attempting to use an update cursor to update a field 'Cost' by multiplying the value in the field 'Area' by a value input by the user. The trouble seems to be getting the variables "Price1" and "Price2" to work inside the cursor's If statements. If I simply replace the variable with a number, such as 2, then the script works fine, but it really needs to multiply a variable that the user has entered. The variable that the user enters will be a money value, so it's of type Double with 2 decimal places. The error I get is "can't multiply sequence by non-int of type 'float'". Here's a snippet of the code:Price1 = float(arcpy.GetParameterAsText(0)) Price2 = float(arcpy.GetParameterAsText(1)) fcName = "My_lyr" fields = ['Area','Description','Cost'] #Note that 'Area' is type DOUBLE, 'Description' is TEXT, and 'Cost' is DOUBLE CostCursor = arcpy.da.UpdateCursor(fcName,fields) for row in CostCursor: if row[1] == "Category 1": row[2] = (row[0] * Price1) elif row[1] == "Category 2": row[2] = (row[0] * Price2) else: row [2] = 0 CostCursor.updateRow(row) del row del CostCursor
