Hi everybody,
I have a field called 'Status' that I reclassify every evening so I can update our symbology on one of my web maps. I wrote a function in Arcade that works, but in the interest of automation I am trying to convert my scripts to Python so I can use them in model builder.
There are 9 fields that contribute to the calculation of the field status. They are:
Date_Found
MIN_Hatchling_Emergence_Date
Data_Type
Washout
Removed
Need_to_Check
Assigned_HS
SOH_yes_no
Treatment_Code!
I am trying to use the Calculate Field Tool. When I click verify it says the expression is valid. The code will run but it returns <null> in the status filed for every feature. I'm not too familiar with Python. Does anybody have any suggestions? I found a few examples online, but they all reclasses based on one input feature.
I enter this in the expression box:
reclass(!Date_Found!,!MIN_Hatchling_Emergence_Date!,!Data_Type!,!Washout!,!Removed!,!Need_to_Check!,!Assigned_HS!,!SOH_yes_no!,!Treatment_Code!)
And this in the Code Block Box:
def reclass(Date_Found,Date_SOH,Nest_or_Crawl,Washout,Removed,Check,Assigned_HS,SOH,TTT):
if Nest_or_Crawl == "Crawl":
if (time.strftime("%d/%m/%Y"))-Date_Found>=7:
return "Old Crawl"
else:
return "Recent Crawl"
elif Washout=="Y":
return "Washed Out"
elif Removed=="Y":
return "Removed"
elif Check =="Y":
return "Check"
elif (Assigned_HS=="N" and
(time.strftime("%d/%m/%Y"))-Date_Found>=70):
return "Ready for Removal"
SOH=="Y" and (time.strftime("%d/%m/%Y"))-Date_SOH>=3):
elif Assigned_HS=="Y" and [(time.strftime("%d/%m/%Y"))-Date_Found>=70 or
(SOH=="Y" and (time.strftime("%d/%m/%Y"))-Date_SOH>=3)]:
return "Ready for HS"
elif Date_Found>=45 or TTT=="9":
return "Look for SOH"
else:
return "Incubating"
Thank you for your time.
