Using arcpy to pan across map's data frame
1220
03-28-2019 02:31 PM
Kevin_C
New Contributor III
I have a total of 150 maps I used arcpy and the Mapping module to create. Everything works and looks fine, except that some maps have features being hidden by an inset data frame. I cannot change the position of the inset data frame, so that's out of the question. Is there a way using arcpy and the mapping module to pan across the map?
Tags (3)
PavanYadav
I wonder if this post: Zoom/Pan to layer using Arcpy
or a combination of the above and the following example, can help you:
df = arcpy.mapping.ListDataFrames(mxd)[0]
newExtent = df.extent
newExtent.XMin, newExtent.YMin = -180.0, -90.0
newExtent.XMax, newExtent.YMax = 180.0, 90.0
df.extent = newExtent
PavanYadav
Also, check this out: panToExtent (extent)
JimCousins
MVP Regular Contributor
I use a bit of python script and pointers to bookmarks to output maps:
for bkmk in arcpy.mapping.ListBookmarks(mxd, data_frame=df):
    LookupText1 = bkmk.name
    df.extent = bkmk.extent
    arcpy.AddMessage(bkmk)
    arcpy.RefreshActiveView()
Let me know if you need some more information on how to do this.
Best Regards,
Jim
