Field Calc, in Model Builder, using strings
847
5
10-30-2019 12:38 PM
ChristopherSmith10
Hello All, and thanks  for any help.
I am trying to take this block of Python and insert it into the Field Calculator.   What it is supposed to do is take a concatenated field (LF_Concat) and from within that field parse out the number of Greens (G), Yellows (Y), and Reds (R) and then apply a If/Than/elif to number of colors.
Right now I am at a loss on how to get it in.  I have this too show for it.  The parser while it shows VB is actually in Python  (I maybe slow, but I ain't that slow)
Progress Thwarted
I suspect that the delineatorList should be changed to the concatenated field (LF_concat)  but I am lost beyond that.
Chris
delineatorList = [" ", ".", ","]
ColorClass =  ['GGGY','GGYY','GYYR']
for letters in ColorClass:
    #print letters, " G = ", letters.count('G')
    #print letters, " Y = ", letters.count('Y')
    #print letters, " R = ", letters.count('R')
    Count_G = letters.count('G')
    Count_Y = letters.count('Y')
    Count_R = letters.count('R')
    if Count_R > 0:
        print "Red"
    elif Count_R == 0 and Count_Y >= Count_G:
        print "Yellow"
    elif Count_R == 0 and Count_Y < Count_G:
        print "Green"
FC_Basson
MVP Regular Contributor
First change your parser to Python.  The definition function declaration should be small caps - "def". And remember Python is strict on indentation.  You can also simplify your "checking" code to something like this:
for c in ColorClass:
    if c.count('R') > 0:
       print 'Red'
    elif c.count('R') == 0 and (c.count('Y') >= c.count('G')):
       print 'Yellow'
    elif c.count('R') == 0 and (c.count('Y') < c.count('G')):
       print 'Green'
DanPatterson_Retired
The first line should be to make it a generic script
def Classify(ColorClass):
and you 'call' it as you have done.  The field name will be passed to the function as ColorClass so there is no need for you ColorClass = … assignment statement at all
And replace FC Basson print statement with return.
 (BTW, the print statement is python 2.7 if you are using ArcGIS Pro print('Red') would be needed)
ChristopherSmith10
Expression:
Classify2(ColorClass)
Code Block:
def Classify2(ColorClass):
       return 'Red'
       return 'Yellow'
       return 'Green'
Executing (Calculate Field): CalculateField WorkLF_P2 LanduseFeas Classify2(ColorClass) PYTHON_9.3 "def Classify2(ColorClass):\n for c in ColorClass:\n if c.count('R') > 0:\n return 'Red'\n elif c.count('R') == 0 and (c.count('Y') >= c.count('G')):\n return 'Yellow'\n elif c.count('R') == 0 and (c.count('Y') < c.count('G')):\n return 'Green'\n"
Start Time: Fri Nov 1 13:52:28 2019
ERROR 000539: Error running expression: Classify2(ColorClass)
File "<expression>", line 1, in <module>
NameError: name 'ColorClass' is not defined
Failed to execute (Calculate Field).
Failed at Fri Nov 1 13:52:28 2019 (Elapsed Time: 0.01 seconds)
So I got it into the code block and now I am attempting debugging.
"ColorClass" is not defined, ...but it is the first line of the code
Thanks again.
expression
Classify2(!LF_concat!)
ChristopherSmith10
D'OH!
Thank you.  Works great now.
