ARC Gis setup with Qt
492
03-02-2022 02:04 AM
KunalK
I am trying to setup arcgis sdk (v100.13) with my existing Qt framework. Below are the details:
Qt Creator 6.0.2
Based on Qt 6.2.2 (MSVC 2019, 64 bit)
I have MSVC 2019 installed. But when I try to run an example from the ARCGIS project I get an error saying:
":-1: error: Project ERROR: untitled17 requires Qt 5.15.2"
If i install qt using the online installer. I automatically get Qt 6.0.2.  I have no control over that. How can i get the precise Qt 5.15.2 version. Please point out the correct qt installation file or any tutorial that has this covered.
AndrewBladon
Hi KunalK.
The Qt SDK is not currently compatible with Qt6.
Now that you have Qt 6 installed, you should be able to install Qt 5.15.2 using the Qt Maintenance Tool. From your message I understand you are using Windows where the maintenance tool is typically found in C:\Qt\MaintenanceTool.exe. Previous versions of Qt can be installed by following the steps below:
  • Run MaintenanceTool.exe.
  • Login.
  • Select Add or remove components from the list and press Next.
  • Under Select Categories, check the Archive checkbox.
  • Press Filter.
  • Once the component list updates, expand the Qt list.
  • You should now see a list of previous Qt versions, including Qt 5.15.2.
  • From the list, select the desired components and install.
Please let us know if the above steps do not resolve the issue.
