Can we create and edit shapefile using API:ArcGIS RT fro Qt
3044
08-12-2015 04:50 AM
kishorekumar1
Hi
      Can we create and edit the shape file using the API in ArcGIS Runtime sdk for qt. If yes can you share the work flow.
Regards,
Kishore Kumar
LucasDanzinger
Esri Frequent Contributor
You cannot do this currently with our 10.2.6 release. At our Quartz release, we are aiming to have support for editing and viewing shapefiles. I don't believe we will have the ability to actually create the shapefile in our API, but you will be able to consume and edit an existing one.
Luke
LucasDanzinger
Luke
