Disable panning
3366
07-06-2015 08:25 AM
PremRadhakrishnan
I am trying to use the MousePress, MousePositionChanged and MouseRelease signals to capture a selection rectangle, the issue that I have is I want to disable panning if a flag is set and then enabled it so that during the action the map does not pan.
Is there anyway to do this?
Prem
LucasDanzinger
Esri Frequent Contributor
You can set up a handler for the mousePositionChanged signal and accept the mouse events depending on if your panning flag is enabled or not. Something like the following should get you started.
Luke
import QtQuick 2.3
import QtQuick.Controls 1.2
import QtQuick.Controls.Styles 1.2
import QtQuick.Dialogs 1.2
import QtQuick.Layouts 1.1
import ArcGIS.Extras 1.0
import ArcGIS.Runtime 10.26
ApplicationWindow {
    width: 500
    height: 500
    property bool isPannable: true
    Envelope {
        xMin: -122.511
        yMin: 37.7474
        xMax: -122.3887
        yMax: 37.8125
        spatialReference: SpatialReference {
            wkid: 4326
    Map {
        anchors.fill: parent
        extent: extentEnvelope
        focus: true
        ArcGISLocalTiledLayer {
            path: "~/ArcGIS/Runtime/Data/tpks/SanFrancisco.tpk"
        onMouseClicked: {
            console.log("clicked", mouse.mapX)
        onMousePositionChanged:  {
            if (!isPannable) {
                mouse.accepted = true;
            } else {
                mouse.accepted = false;
    Button {
        text: "disable panning"
        onClicked: {
            if (isPannable)
                isPannable = false;
            else
                isPannable = true;
LucasDanzinger
Luke
import QtQuick 2.3
ApplicationWindow {
    width: 500
    height: 500
    Envelope {
        xMin: -122.511
        yMin: 37.7474
        xMax: -122.3887
        yMax: 37.8125
            wkid: 4326
    Map {
        focus: true
        onMouseClicked: {
            if (!isPannable) {
            } else {
    Button {
        onClicked: {
            if (isPannable)
                isPannable = false;
            else
                isPannable = true;
