I'm trying to generate a somewhat large geodatabase, it has 7 layers but a few of them have image attachments and the whole thing comes out to several gigabytes. When I run this using the code in the qml sample for v100, it takes about 20 minutes and then says "File not found Error with download, geodatabase file is not present at the expected path.". If I remove some of the layers from the replica request, this does not happen. Does anyone know what might be going wrong or how I can further test this?
Additionally, running the same task on Android results in the app just spontaneously closing with no message of any kind in Qt Creator or on the device. I'm assuming this is an out of memory exception as the task eventually uses 6GB of ram on my desktop. Is there any way to get the task to run safely on mobile, or are we going to have to pre-generate geodatabases and download/register them to get around this?
Jon
