There is not a setting to enable this. In theory, you should be able to set allowOverlapOfLabel:avoid and allowOverlapOfFeatureInterior:avoid, and this would enable the dynamic movement of the label to avoid overlap, but accept overlap when it couldn’t be avoided. However, we tested this out and it seems like there is a bug, so this won't work at the moment. We are looking into it.
