SampleViewer and stylx
1340
5
07-20-2017 01:06 AM
NorbertThoden
Occasional Contributor III
Hi!
I am migrating to V100.1.
On my office computer i have installed the SampleViewer V100.0 as well as the SampleViewer V100.1.
I am working with the Topic "search" to analyze the content of th DictionarySymbolStyle (based on the stylx file)
I was wondering that both versions are displaying the same number of total results: 6894
When is install the SampleViewer V100.1 on my private computer the total number of results is 6182.
(I am using the identical zip-File to start the SampleViewer)
Whats is going on here?
LukeSmallwood
Hi Norbert - sorry, I wasn't very clear. The data used by the samples is downloaded on demand and goes to a separate location (based on the Qt home location) - depending on your platform it will be something like:
- Windows: c:\Users\[user_name]\ArcGIS\Runtime\Data
- Mac: ~/ArcGIS/Runtime/Data
- Linux: ~/ArcGIS/Runtime/Data
LukeSmallwood
Hi Norbert, I believe there have been some updates made to the stylx file for 100.1
The sample, when run from the viewer, will download the file if it is missing - possibly both samples viewers are using the same (older?) version of the file.
If you delete the file from ...ArcGIS/Runtime/Data/styles/mil2525d.stylx and run again it should download the latest version.
Please let me know if you are still getting inconsistent results.
Luke
NorbertThoden
Hi Luke!
I speak about the SampleViewer which can be simply downloaded and extracted.
In that area i can`t find the path "...ArcGIS/Runtime/Data/styles/mil2525d.stylx".
I already searched for that file but without success...
And there is no SDK installed.
Is the stylx file compiled in?
Thx
LukeSmallwood
NorbertThoden
Thanks Luke!
Now i can understand what was going on.
From my point of view it´s tricky. I downloaded and installed the SampleViewer of V100 a cvouple of month ago,
Now i try to use the new one of V100.1 and the result are not correct (dur to old stylx).
Using this (wrong) data it´s hard to discuss with the problematic changes of the stylx:
https://github.com/Esri/joint-military-symbology-xml/issues/338
very short overview:
I recognized a bug relatedt to a military symbol, create a case and got a bug-Number.
A couple of month later that bug arise in that github repo.
A couple of people solved that partly, but ESRI is not able to explain what is solved and what is still open.
After the release of V100.1 i try to analyze...
From my current point of view the inconsistency increases and the usablity of thatr symbol decreases...
More than half a year to replace one problem with another.....
Now i have dig into that problem further...
But Luke, thanks for your great help at this time 🙂
(For you it´s at night, right?)
Norbert
LukeSmallwood
Hi Norbert - thanks for the feedback, I will pass that on.
I'm based in Scotland so it's morning here for me.
Luke
