I am trying to add an item from Enterprise Portal to MapView. I'm trying to add the item, which is a FeatureLayer using its itemID. See code below.
MapView {
anchors.fill: parent
Map {
BasemapDarkGrayCanvasVector{}
initialViewpoint:
ViewpointCenter {
targetScale: 1.5e7
Point {
x: -11099972.04
y: 4014041.26
spatialReference: SpatialReference {
wkid: 102100
FeatureLayer {
visible: true
Component.onCompleted: {
mapView.map.operationalLayers.append(structuresInspectionStatusFS)
ServiceFeatureTable {
initItem: inspectionsStatusPortalItem
initLayerId: inspectionsStatusPortalItem.itemId
onLoadStatusChanged: {
onLoadErrorChanged: {
console.log(layer.name)
console.log("Error changed:", loadError.message)
onErrorChanged: {
console.log("Error2 changed:", error.message)
PortalItem {
itemId: //itemID
portal: portalMain
if (loadStatus === Enums.LoadStatusLoaded){
structuresInspectionStatusFS.item = inspectionsStatusPortalItem
Portal {
credential: portalCredential
url: "Portal URL"
portalMain.load();
if (portalMain.loadStatus === Enums.LoadStatusLoaded) {
inspectionsStatusPortalItem.load()
} else {
Credential {
username: "username"
password: "password"
Connections {
target: AuthenticationManager
onAuthenticationChallenge: {
if (challenge.authenticationChallengeType === Enums.AuthenticationChallengeTypeUsernamePassword) {
challenge.continueWithCredential(portalCredential);
This used to work in AppStudio 4 and its Runtime, but now that I've upgraded to AppStudio 5 and latest Runtime, it doesn't work anymore. I get an "Invalid Argument" Error from the error signals on ServiceFeatureTable.
I know it's not an authentication issue, because I have other FeatureLayers that I'm adding to the map and they work fine. The difference is that those FeatureLayer items don't get added as PortalItem.
Any help is appreciated!
Application Developer, GeoMarvel
