Has anyone successfully run an R-based script tool on an Enterprise server -- that imports the sf package? Or even the stats package. I’m having this issue when trying to run an R-based script tool as a published geoprocessing service. I’m using ArcGIS 3.2.1, R 4.3.3, and ArcGIS Enterprise 11.2.
I do have R (v 4.3.3) installed on the server machine. The `arcgisbindings` and the `sf` package are both installed; I installed them while logged into the server machine using the ArcGIS Enterprise service account. I can confirm the sf package is installed by running `library(sf)` at the R command prompt, which runs without warning or error.
I’ve worked with three separate ESRI technical support specialists over the last month on this issue. However, I don’t believe any have worked with R. In the end, they told me that ESRI does not actually support the R-ArcGIS Bridge on an Enterprise Server (despite it showing up quite clearly in their Enterprise documentation).
I’d really like to know whether anyone has been able to get R-based tools that call 3rd party packages to work in a published geoprocessing service as that would suggest it’s an issue with my set up. And of course, if it is an issue with my set up, I’d love pointers on what I might tinker with.
Thanks for any advice you can provide.
