Overlay Route Events Error (ArcMap 10.8.1)
771
12-27-2022 01:48 PM
Labels (2)
BJCovington
New Contributor II
I am attempting to overlay several events against our network layer and keep running into the following error:
Any ideas?
AmitHazra
The Overlay Route Events GP tool requires inputs to be part of an LRS dataset so you will need the LRS_ tables in your local staging geodatabase.
Thanks
-amit@esri
KarolFrancisAZ
New Contributor III
Hi BJ - have you tried running the tool in a model? I've only been able to get this tool to work inside a model.
AmitHazra
Hello -
Can you verify whether the GDB connected user you have specified for the connection to the LRS network and events has read access to the Lrs_* business tables (Lrs_metadata, Lrs_EventBehavior, Lrs_Locks etc)...
-amit@esri
BJCovington
New Contributor II
The events are in a local staging geodatabase (not connected to the R&H deployment) separate from the LRS. It appears that I would need to import these into same geodatabase in order for the tool to work?
AmitHazra
Thanks
-amit@esri
