ReferenOffset in event editor
692
11-28-2019 12:47 AM
Labels (2)
MajaMesserli
Hello
We record road data in the event editor. When positioning events using our reference point system, the exact position (reference point + offset) is converted into coordinates and then into measures values (of the route element). The event object is placed correctly. However, the "fromReferentOffset" and "toReferentOffset" values are stored as rounded integer instead of the original offset value.
Why is this and can it be changed?
thank you for your help.
Maja
NathanEasley
Hi Maja,
I would suggest opening a case with Esri Technical Support for this issue.  When you log the issue, make sure they know it's for Roads and Highways and the Event Editor application.
Nathan
Esri Roads and Highways team
MajaMesserli
Hello
The case has been logged as BUG.
BUG-000128179
