Similar to how in ArcGIS Pro, where you can set the Depth Priority of each 3D layer (https://pro.arcgis.com/en/pro-app/2.9/help/mapping/layer-properties/set-depth-priority-for-a-3d-laye...), it would be quite helpful to have the same capability in Scene Viewer on Portal for ArcGIS.
Currently in Scene Viewer, have z-fighting artefacts ('tearing') from different web scene layers
This is in our backlog but not yet planned for a release.
Could you please share the use case(s) you are trying to solve? Or why are you forced to visualize several layers at the same visual depth simultaneously?
This helps us to prioritize our backlog.
