Please add the capability for the Scene Viewer to show weather animation depending on the actual weather of the area at the time of viewing the area/scene. This should be an option that could be toggled on/off.
Thank you
@Ed_ - This is currently not yet in our backlog.
Could you please share the use case(s) you are trying to solve? This helps us to prioritize our backlog and roadmap for the upcoming releases. Thanks.
Happy Monday @GianlucaMiele1 hope all is well and thank you for your response. Right now the weather widget is cool as it shows 3D with respect to different weather conditions. But, it will be more practical and relatable if linked with real time weather conditions of the area. For example, this can be coupled with live weather forecast. Say if the weather forecast is sunny then the weather widget would also default to sunny.
