Curve Fit tool for Arcgis 10.2
6027
07-14-2014 10:31 PM
SharadGupta
New Contributor II
For regression analysis between images (Raster Regression) curve fitting tool
Curve Fit : A Pixel Level Raster Regression Tool - Desktop Decision Support Tools
DanPatterson_Retired
Please put some tags on this item to ensure the widest audience
SharadGupta
New Contributor II
Thank you for your suggestion.....
KarenF
Hello,
I am having problems installing the "Curve Fit" extension on ArcGIS. "Fox Tools" in the Categories list doesn't appear after installation (step 7 in the instructions or installation).
Curve Fit Installation:
1) Unzip Curve Fit.zip
2) Close all instances of ArcMap 10.x
3) Run Curve Fit.msi, install Curve Fit to a local drive
4) Start ArcMap 10.x
5) Click on the Customize menu and then the Customize Mode... menu item
6) On the Customize dialog, click the Commands tab
7) Scroll down and click on Fox Tools in the Categories list
😎 Drag the Curve Fit button to a toolbar on the ArcMap 10.x interface
Do you know to what this problem could be related? Maybe you have had the same kind of problem and could help me.
Thank you in advance,
Fjøsne Karen
