I just figured this out the other day. You can use the Offset function in Arcade. Here's the code that I use to calculate the neighborhood on the left-side of a road segment.
//Set the neighborhood dataset, selecting only the neighborhood name field.
var fsNbrhd = FeatureSetByName($datastore, "GIS.DBO.Neighborhood", ["nbrhdname"])
//Specifies the left-side of the road. If the offset is greater than 0, it will be the right-side.
var RoadLeft = offset($feature, -1, 'feet', 'square')
//Selects the neighborhood polygon on the left-side of the road.
var fsNbrhdLeft = Intersects(fsNbrhd, RoadLeft)
//Returns only the first intersecting polygon, in case there are overlaps.
var NbrhdLeft = First(fsNbrhdLeft)
if(NbrhdLeft == null) return null
//Returns the name of the first intersecting neighborhood polygon on the left-side of the road segment.
return NbrhdLeft.nbrhdname
