Hello community,
I have a problem analysing the data of my master thesis. Hopefully someone can help me.
I have tracked many dogs and their owners with GPS while hunting and now I want to measure the distances between these two "moving point objects" over time.
By now I load the GPS Data in ArcGIS and make a tracking layer out of it, so I can use the Playback Manager of the Tracking Analyst tool. I set it to 1 minute per second and go manually through it and measure the distance at every step per hand. This costs a lot of time, especially because I have a lot of these tracks.
So my question is: is there a solution to get a table or a graph of the distances between the two objects over time automatically? That would help me so much!
Thanks in advance,
Lena
Solved! Go to Solution.
Thanks for the data, I had a fiddle with it.
First I used the dnr garmin program to read the gpx track files to points (as text & shapefiles).
Then I created a personal geodb (access) and loaded the data from text.
Unfortunately, the time stamp info in each file (ltime), won't automatically come in as a time/date field, have to first import it as text, then update it into a newly created TimeStamp field of time/date type. Confusing huh...
As I said previously, you can create a series of queries which join one file to the other based on a minimum time difference between them.
Have a look in the mdb file zipped attached.
From the matched table I used the XY table to line tool to create the joining lines. Then added a distance field, changed the projection of the df to UTM32N and calculated a metres distance / length.
Hope this works for you.
Couldn't you use some variant of the code posted here by Dan Patterson..
The approach seems about right. But as I am new to Python I don't see how I can implement the time in that code.
Well, that post was in answer to another question from a user here. About distances between street poles or something.
If you want further guidance, I think you should be a little more specific about your data, its attributes and exactly what you want to achieve.
Since you have gps data, I presume that you have the coordinates of the values. Suggested workflow
I presume you can get delta time from the time data if needed, but the cumulative values will facilitate graphing
Addition
Have you ruled out the time tools listed here from the tracking analyst toolbox?
That doesn't really help me for I don't need the distances between points of the same track but between two points of two different tracks at the same time.
Ahhh. I presume then, that you have examined the time data and ruled out joining the tables based upon a common time? I doubt a simple join will exist, so it might be worthwhile to parse/summarize your data into some common time increment. Once that has been established then the feature location at those times could be derived. Do you have an example of two files (a small sample) to show the form of the data?
Ah, I see.
I don't know of any ArcGIS tools to do this, as its nots really a spatial problem but more of a time stamp matching problem.
I have done this in the past for correcting geophysical readings (rover vs base station) and basically did the matching in Access by finding the minimum time difference between records in each file. And I suppose we could also do this in python as well.
But some example files would be a help.
