BUG in Ripleys K Function
510
09-18-2010 08:43 AM
RobertoFuentes
I have a point data set representing 'Plants' across a vast range.  The point data set does not contain a boundary... its just a collection of points.
I would like to perform a Multi-distance Spatial Cluster Analysis (Ripleys K Function) on my data set.
I am Utilizing ArcMap10 on a Windows 7 machine.
Here are the parameter inputs:
featureclass_plants
output table
Number of distance bands: 10
Confidence Interval: 99_permuations
Display results checked
Weight Field: Blank
Beginning Distance: 0
Distance Increment: 2
Boundary Correction Method: Ripley_edge_correction_formula
Study Area Method: Minimum_enclosing_rectangle
The calculation FAILS.  The error that it throws is:
<type 'exceptions.KeyError'>:28L
The problem is with the Boundary Correction method.
If I use NONE or SIMULATE OUTER BOUNDARY VALUES, the calculation works.
If I use RIPLEYS EDGE or REDUCE ANALYSIS AREA the calculation fails.
I am assuming it is a BUG in Arc10 because it works fine in 9.X.
Any suggestions??
MarkJanikas
Hello wisfool,
I am the programmer for the tool and I would be glad to help you out.  Would it be possible to send me your data?  We have quite a few harness tests for "Ripley" and "Reduce" and we are not getting the error.  If you cannot send me the data, then perhaps I could get in touch with you remotely to try and debug.  You can reach me at my coords:  mjanikas@esri.com
Thanks so much,
MJ
