Thank you very much, Chris. I used Union and then calculated the area ratios with the Field Calculator. First calculate geometry of layer A, then Union, then calculate geometry of the new polygons, then calculate the ratio of the two numbers. I was hoping for something more elegant that leaves me with the old polygon sizes and their area ratios written to the attribute table. This Union way is a bit less elegant, but it also works.
