Hi.
I am running GWR in my research and I don't know what do mean column 'Significance' and 'Pseudo-T' in attribute table after running GWR. These are new column in layer's attribute table after running GWR. What does it mean this 0 and 1? Can anyone help me.
Thank you.
Solved! Go to Solution.
Hi Mirela,
The "Significance" column in the attribute table indicates whether the parameter estimate for each variable is statistically significant or not. A value of 1 indicates that the parameter estimate is significant at the specified level (usually 95% confidence interval) and a value of 0 indicates that the parameter estimate is not significant.
The "Pseudo-T" column in the attribute table represents the t-statistic for each parameter estimate in GWR. The t-statistic measures how many standard errors the estimate is away from zero. The larger the absolute value of the t-statistic, the more significant the estimate. The significance level of the estimate can be determined from the associated p-value.
More about the GWR here:
How Geographically Weighted Regression (GWR) works—ArcGIS Pro | Documentation
Best,
Omar
Geographically Weighted Regression (GWR) (Spatial Statistics)—ArcGIS Pro | Documentation
for reference and see
under Interpreting messages and diagnostics
Hi Mirela,
Best,
Omar
Thank you very much. Yes, it helps.
Hello. What column is the associated p-value? I have the following fields:
Std. Error, Pseudo-T, Predicted , Residual, Std. Residual, Influence, Cook's D, Condition Number, Local R-Squared. Can you explain each of these? I can't find any documentation on them.
Hi. The associated p-value can be determed according to the Pseudo-T, Student's table and degrees of freedom.
In my case it was 0.01or 99% significance. I don't know if it vould be determinated before running the GWR.
For other statistical indicator you wrote look at some book about statistic. I also can't find any documentation on them. Local R-Squared is R-Squared for each entity in the attribute table (rows in attribute table).
I hope it helps.
Mirela
I got confused regarding the equation used to calculate the Cook’s D.
https://www.machinelearningplus.com/machine-learning/cooks-distance/
https://www.statisticshowto.com/cooks-distance/
https://www.youtube.com/watch?v=PVJYdMjfrAA&t=580s
