Can we assume that you toggle on the extension? (Customize, Extensions check on the extension)
Now, it will have an X until you navigate to a featureclass on disk. So locate your geodatabase and select an appropriate featureclass.... or locate the folder containing your shapefile... whatever the case is
... sort of retired...
