I'm using arcGIS Pro and I have a data of zip codes with a count of how many cases per zip code. I'd like to use the US Zip Codes file to visualize each count as mapped onto each zip code area. I wasn't sure if you're supposed to use a Summarize Within, or a Spatial Join, or something else, and which direction/file to join on to which one.
Here is what I have so far; two layers where the yellow is the US Zip Codes, and the dots are the value of the count for each zip code.
Thank you so much! Happy to proi
