What are the assumptions of the Getis Ord Gi* spatial statistics test? Do data need to be normally distrubited, ect.?
3301
06-23-2016 06:56 AM
MattFolley__DOIT_
Does not seem to be solid list in any of the tutorials or online help. Is the test still robust if inputs are not normally distributed?
DanPatterson_Retired
You should read the original references at the end of this page rather than relying on a help file comment
How Hot Spot Analysis (Getis-Ord Gi*) works—Help | ArcGIS for Desktop
plus there are some good resources cited here
Spatial Statistics Resources | ArcGIS Blog
And to interpret statistical results for tests where the underlying assumption is complete spatial randomness, then inferences can be made from the discussion of z-scores and p0values
What is a z-score? What is a p-value?—Help | ArcGIS for Desktop
