I am trying to update a new point feature with data joined to an underlying polygon feature class.
Background: The polygon feature class has the geometry of city boundaries and resides within an SDE feature dataset. The joined table right now resides in my local c:\ drive, and contains two additional fields that I need for the attribute assistant application.
When I initially tested the join in AA, it failed and I figured it did because I referred to the alias field name in the DynamicValue table:
(Both the 'ESN' and CommunityCD fields are from the joined table.) However, after making the change, the logfile complains that it cant find the field name:
Row Info
Row Number 17
TableName: MasterStreetNameFC
FieldName:
ValueInfo: slcopub.SLCO.Municipalities|ESN_CommunityTable.ESN,CommunityCD,ESN_CommunityTable.CommunityCD|ESN, ZipJurs,CityJurs
ValueMethod: NEAREST_FEATURE_ATTRIBUTES
On Create: 1
On Change: 0
Checking for Subtype Restriction
Field is not specified, empty, or set for all.
Trying: NEAREST_FEATURE_ATTRIBUTES
WARNING: search distance as not specified, defaulting to 0
Looking for layer: slcopub.SLCO.Municipalities
slcopub.SLCO.Municipalities layer Found: slcopub.SLCO.Municipalities
Checking Field Mapping
ERROR: Cant find field ESN_CommunityTable.ESN in table slcopub.SLCO.Municipalities
Finished: NEAREST_FEATURE_ATTRIBUTES
Perhaps another set of eyes can see what I'm not; is it a path problem to the SDE/feature dataset,?
Does not work with joined fields
Could you make a database view to join those tables so it appears as a single table to the AA?
I'll give that a shot. Thanks!
