Create a Road and Split Intersecting Road Tool in Address Data Management Template
4006
06-06-2015 03:07 PM
JeffWard
I am running into a hitch when adding streets using the Address Data Management template from the local gov solutions site.  The help says that any new roads added using the Create Road and Split Intersecting Road tool will split any intersecting roads (plural).  But I am only getting it to split one road if it intersects two roads.
Is that expected behavior?
Jeff
Jeff Ward
Summit County, Utah
JeffWard
Crickets.
Jeff Ward
Summit County, Utah
JasonBalmut
Jeff, after 3 long years you get an answer.  It appears to only split the starting road segment, not the one it ends on.  I don't know if that was the intent.
