How would I determine what COGO fields to enter?
1000
08-09-2017 10:59 AM
deleted-user-GOuXPKo6LOX6
I have a survey plat where I need to enter some COGO values for an easement boundary, but I am having trouble figuring out what the abbreviations in the plat mean and what to enter them in COGO as.
The values in the plat are:
A = 8.43
^c = 20-36-35
Rc = 23.44'
I've attached a screenshot of the actual plat map.
Thanks!
EmilioSolano
Hi Blake,
In case you haven't got the answer yet:
A = is the arc length (8.43) in feet
^c = is the angle of the curve (20-36-35) degrees-minutes-seconds
Rc = is the arc radius (23.44') in feet
 The two curves are tangent reverse curves.
Hope this helps,
Emilio
EmilioSolano
Hi Blake,
Hope this helps,
Emilio
