Has anyone else ever received the following error message when running the Append tool, but found that the records were copied into your dataset?
Error: ERROR 000372: Spatial Reference for output is invalid, Please update to allow output to become valid
Failed to execute (Append).
I understand how this may be a technical error, but because the records were copied over, it almost seems like a false positive. Does anyone know why this is an error message instead of a warning? Typically when you get an error message, the tool failed. But in this case, the records were appended.
