LGIM Coordinate and Extent?
3079
03-21-2013 12:37 PM
KevinKuhn
New Contributor III
Hi All,
I am experimenting with implementing the LGIM, using SQLExpress.  I am just now setting up the geodatabase, and have no data loaded.  I have a fairly basic question.
The LGIM.xml has a coordinate system  (and extent) of N illinois...   I would like to use WV State plane... however, I am concerned that if I just re-project it, the extent will not be correct.  I have also thought about just over-writing the coordinate system, however, it does not change the extent.  Should I worry about the extent at all or just re-project the datasets.  When I create a new geodatabase, it automatically uses the projection from the data model (Illinois).
Thanks!
PS... the instructions provided says:
Step 3: Create an empty geodatabase schema and configure the model to meet your specific needs.
Use the XML workspace document to create an empty LocalGovernment.gdb for your organization. When you create the empty schema, make sure you specify the proper coordinate system and spatial reference. Once you�??ve created the empty schema, add any features, fields and domain values you may need to support your implementation. If you want to localize the field names in your maps, we encourage you to use map layer or field aliases and not change the underlying field names in the LocalGovernment.gdb. If you do change a field name, you may also need to alter the editing map, mobile, or web app.
ScottOppmann
Kevin -
Here is a link that will help you set the spatial reference properly for the local government information model.
Scott
ChrisJensen
New Contributor III
I have tried the link you refer to .  step 3c: In the X-Ray for geodatabases window, click Options > Use Spatial Reference -
"use Spatial Reference" is disabled under options in x-ray.    I just started playing with this tool.  Any suggestions?
HeatherEisan1
New Contributor III
commonman you need to either select a feature dataset of feature class selected in the geodatabase that has the proper spatial reference in order for the use spatial reference to be enabled.
