This will also work, but this will not work on 'non simple' data. An example of non simple data is a feature class that participates in a relationship class. For example, if the feature class has attachments enabled, you will receive an error when trying to right-click on the feature class in the Catalog window > Load > Load Data:
However, the Load Objects command in ArcMap will allow you to load data into non simple data.
