Hi Tom,
Based on the information you provided, I'm thinking that managing them as encumbrances would be the way to go. Obviously all geographic features aren't required to be managed in the fabric, but if they tend to have some sort of survey description then fabric features is an option. Because all of the features are linked together in a kind of network, you don't have to worry about duplicating boundary resurveys. In other words, topology is inherent and as long as the overlapping polygon types are "joined" any resurvey of a shared line will be updated multiple times.
Another option would be to use a "feature adjustment" and associate the patented claims to your fabric parcels. This works by applying any displacement vectors stored on the parcel points to the associated features such that a shared corner of a patented claim will be adjusted to shifts in coincident parcel points when you run the feature adjustment. The main difference here is that the user has a little bit more control and QA over the adjustment and the associated feature is loosely tied to the parcels (no real survey).
