Luci,
I finally figured this out!! I was having the same issue. If you open the locator.js file, then go to line 436
td.className = "selectedPark";
if (featureSet.distance) {
td.innerHTML = featureSet.name + " (" + dojo.number.format(featureSet.distance.toFixed(2)) + " miles)";
} else {
td.innerHTML = featureSet.name;
Remove the + " (" + dojo.number.format(featureSet.distance.toFixed(2)) + " miles)"
Should look like this:
td.innerHTML = featureSet.name ;
} else {
I hope this helps.
If I figure out to change the location to display the correct miles I will post it on this discussion.
