Original User: lind5149
Hi Jordan,
The error message is saying reportlab isn't there....Let's manually check in the 64-bit and 32-bit locations...
Do you have these locations on your machine or machine(s) ?
<yourdrive>:\Python27\ArcGISx6410.1\Lib\site-packages\reportlab\pdfgen
<yourdrive>:\Python27\ArcGIS10.1\Lib\site-packages\reportlab\pdfgen
As for the other issue....
Please try running the generatecsv in ArcMap, and make sure the output parameter of the toolbox is set to %scratchfolder%...
In ArcMap verify the output is written to your %scratchfolder%.
Hopefully this helps.
Cheers,
Lindsay Thomas
