Scott,
Try the following, using the Spatial Join Tool in ArcMap or Pro:
1) SetTarget Features - Buildings
2) Set Join Features - FloodZones
3) Set your output Feature Class
4) Join Operation - JOIN_ONE_TO_ONE
5) In the Field Map section
ArcMap
Right click on the name of your Zone attribute in your FloodZone feature
Select - Merge Rule > Maximum
You can also remove any fields that you do not need from the Field Map using the "X" button.
Pro
Select the name of your Zone attribute in your FloodZone feature
Set the Merge Rule to Maximum
You can also remove any fields that you do not need from the Field Map by right clicking.
Set the Match Option to Intersect
6) Run the Join
10.7 ArcMap
2.4 Pro
The resultant joined feature class will have the Maximum value assigned from the FloodZone to the Building.
