Using Address Data mangement map, address managment addin and attribute assistant add-in.
3361
11-12-2014 01:30 PM
by Anonymous User
Not applicable
I am using the Address Data mangement map 10.2, the address managment addin and attribute assistant addin  I need to write some address attributes to some additional tables outside of the geodatabase after adding a new address.  Where should I put the code to do this and what type addin should I use?
CharlineAvey1
I think you only need to add the other data sources into the Map and then add what you want to do to the dynamic value table that is in the map document.  It will see any feature you have in the map document.
Refer to the attribute assistant help to determine what actions you want the attribute assistant to do and when to do it.
Hope this helps
