Communications Utility Network Foundation (Esri)
27275
74
09-22-2017 09:00 PM
SpatialNinja
The Esri team is continuing to refine and improve the data model for comms data management on ArcGIS Utility Network Management. Use this thread to provide input on the requirements of the data model, capabilities of the telecom network, ask questions about the network, access early versions of data models, and stay up to date on the latest news.
Communications Utility Network Foundation (Story Map)
Communications Utility Network Foundation Workflows (Story Map)
PNI ModelsStatus Last UpdatedSoftware Requirements
Fiber, Coax, Copper, WirelessVersion 1.3 Released November 20223/27/2023Introduction to Communications Utility Network Foundation - Requirements
Join the Discussion Below!
- Esri Telecom Team
 telecominfo@esri.com
Solutions Engineer | Spatial Ninja  | GIS ️ | Telecommunications
MikeMillerGIS
Esri Frequent Contributor
What is the version of your UN?
DamianoMontrasio
New Contributor III
Version 5
Maybe it's necessary to disable topology? I've never read that is mandatory.
Maybe lock problem?
Thanks for your interesting Mike...
Damiano
MikeMillerGIS
This looks to be BUG-000152404.  We are going to look at how we can relax the checks in the Asset Package tools so you can get the data exported to an asset package.
MikeMillerGIS
We really should make this conversation its own post.
Can you send me the XML?  A Schema only version is fine.  I am not sure what is going on.  You do not need to disable topo.  Actually when you transfer a UN via XML, the internal tables are not transferred, so it is being transferred disabled.
Is there anything in your target GDB or is it a fresh/clean copy of SQL?
MikeMillerGIS
If you open a python command prompt and enter this, what does it say?
import untools
d = untools.describe_un(PATH_TO_UN)
d.database_owner
