Field calculator calculate mean values of multiple rows when some values are Nulls
5850
12-10-2013 04:31 AM
by Anonymous User
Not applicable
Original User: AnneKull
Hello!
I need to calculate average value of 7 fields (Index2006, Index2007, Index2008, Index2009, Index2010, Index2011, Index2012) to field IlvesAve (see illustration).
[ATTACH=CONFIG]29714[/ATTACH]
The problem is that I have Null values in many rows. 0 values are real counting data, while Null values indicate the missing data. Null values can't be taken into account otherwise the results are incorrect. I can calculate sum value of indexes:
Code:
def stack(item1,item2,item3,item4,item5,item6,item7):
  itemList = [item1,item2,item3,item4,item5,item6,item7]
  myList = [item for item in itemList if (item != None)]
  return count(myList)
Expression:
stack ( !Index2006! , !Index2007! , !Index2008! , !Index2009! , !Index2010! , !Index2011! , !Index2012! )
[ATTACH=CONFIG]29715[/ATTACH]
But I do not know how to calculate mean or count. I cannot divide sum value with a constant because there are always different number of fields with non Null values that need to be taken into account. Can anyone help me?
Best regards
Anne
by Anonymous User
Not applicable
Original User: Pieman86
Hi Anne,
In the Python codeblock, you can define functions like the following:
def count(fields):
    return len([f for f in fields if f != None])
def sum_value(fields):
    return sum([f for f in fields if f != None])
def mean(fields):
    return None if count(fields) == 0 else float(sum_value(fields))/count(fields)
Then calculate your expression using the following:
count ( [ !Index2006! , !Index2007! , !Index2008! , !Index2009! , !Index2010! , !Index2011! , !Index2012! ] )
sum_value ( [ !Index2006! , !Index2007! , !Index2008! , !Index2009! , !Index2010! , !Index2011! , !Index2012! ] )
mean ( [ !Index2006! , !Index2007! , !Index2008! , !Index2009! , !Index2010! , !Index2011! , !Index2012! ] )
Note the use of an array ( [ ] ) to pass in your fields.
AnneKull1
Hi Simon,
Thank you very much. These scripts work well.
Best regards,
Anne
by Anonymous User
Not applicable
Original User: xfuentes
I had trouble running this code so I thought I should share what I did to make this running. I am using ArcGIS 10.1.
Pre-Logic Script Code:
import numpy
def mean(fields):
    return numpy.mean([f for f in fields if f != None])
Expression (selected field in ArcMap Table):
mean([ !Index2006! , !Index2007! , !Index2008! , !Index2009! , !Index2010! , !Index2011! , !Index2012! ])
ChrisPedrezuela
Occasional Contributor III
Here is a sample code for the field calculator:
def mean(field1, field2, field3):
  fieldList = [field1, field2, field3]
  validList = []
  for i in fieldList:
    if i != None:
      validList.append(i)
  meanVal = sum(validList)/len(validList)
  return meanVal
Hi Xavier! I think importing numpy for this case is a bit of a stretch since youll have to load numpy everytime you iterate thru the rows.
Hows Davao by the way or are you in Manila?
regards,
Chris P.
